engine cleaning
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 418
02q45
• bushkill, PA, USA
• Registered on 7/16/2005
• 18 posts
Posted:7/26/2005 17:24
Would it be ok to steam clean an engine and everything under the hood?
Posted:7/26/2005 19:11
You can use a pressure washer but I'd stay clear of heavy detergents and not get the spray tip too close to the engine parts.
Typically what I do is make a lite mix of Simple Green with warm water and spray the engine down with the mix. I leave it on for about 10-15 minutes to lift all the dirt and oils. I take the hose with a variable spray pattern gun to rinse it all down then use a batch of clean terry towels to dry the engine area all off.
Be sure to cover the alternator and power steering pump prior to getting started tho.
Posted:7/27/2005 07:19
I've had good luck spraying the engine down and then using a product made by Gunk (I believe) that's an engine foamer. You spray it on, it foams up, let it soak for a few minutes, then rinse off. Does a really nice job. Make sure to clean/wash the engine when it's cool.
Posted:7/27/2005 07:39
High pressure water is not your engine's best friend
if you really know your engine well - you can stay away from the sensitive areas, but I'm like E,
I let soaking and rinsing do it instead of high pressure....
(that is if I EVER open my hood - I'm one of those drive it until it tells me something is wrong types)
and like CHP said - no harsh stuff that will eat your plastic/electronics/etc...
edited 7/27/2005 12:02
02q45
• bushkill, PA, USA
• 18 posts
Posted:7/27/2005 09:35
Thanks guys.
engine cleaning
