Power Steering Flush
Thread Statistics:     Users to Post: 4   |   Total Posts: 8   |   Total Views: 1179
scott young
• Lexington, KY, USA
• Registered on 9/30/2004
• 29 posts
Posted:8/18/2005 13:05
Guys,
Have any of you done a power steering flush? I have a few extra quarts of Mercon leftover..If you have done it, can you please post on how to do it..
Thanks a ton,
Big Rig...
scott young
• 29 posts
Posted:8/18/2005 13:06
Oh by the way...
I have a 02 Ex with the V-10...
Big Rig
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:8/18/2005 21:55
I did do it, but only after I changed the power steering pump. If you want to do a flush, your lookin at about 3.5 quarts, take the return line off the pump, and let it drain. Are you having pump noise, or just want to do the flush?
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
scott young
• 29 posts
Posted:8/19/2005 08:24
Scott,
No problems...Just wanted to flush it out...
Where is the return line at???
Scott...Big Rig
Scott Stover
• 354 posts
Posted:8/21/2005 22:06
I dont remember which one is the pressure line, I think if your looking up at the pump from underneath its the rear line, then you just drain it that way. Like I said, it will take about 3.5 quarts, if not more....so I think I bought 5 quarts just to be on the safe side. I also put some Marvel in it to keep things lubed up good!! Knock on wood-no issues since. Good luck buddy!
K&N
Gibson Catback
"Custom" Kickplates
Phillip Beall
• Honey Grove, TX, USA
• Registered on 11/7/2004
• 66 posts
Posted:1/22/2007 23:33
Scott,
In this post you asked about any noise. When you drop our Ex out of neutral there is a growling noise that started a long time ago, and which I can't isolate to the power steering pump, power brake pump, or anything else... If I had to guess it would be the power brake since it occurs when I put it into gear, but it only occurs at idle RPM.
Have you, or anybody else, got any theories, diagnostic and treatment suggestions, etc.?
Phil
02excursion73
• Herndon, VA, USA
• Registered on 1/8/2007
• 46 posts
Posted:1/23/2007 20:43
I would recommend having a shop do the BG power steering flush with there special flush machine and cleaners to do it right. Log onto www.BGfindashop.com to find a shop in your area.
Ford pwer steering pumps are noisy when the fluid is old and dirty.
