U Codes & A Codes????????????
Thread Statistics:     Users to Post: 4   |   Total Posts: 8   |   Total Views: 627
Aug250
• Miami, FL, USA
• Registered on 4/15/2005
• 76 posts
Posted:9/30/2005 10:07
Ok I have a set of U codes off my old F-250 sitting around and a set of A codes off a buddys F-350 that I can have for free. The question is as follows, How much lift will I get from these springs ? I have heard everything from a 1/2" to 1.25" in the front and from 0" to 1.5" in the back. Thanks guys I appreciate any help you can give me.
AUG
2005 EX 6.0 4X4 EB, 3" DR, 33" MT ATZ's, Landyot RR, Hoodblanket, Weather stripping mod, Zoodad, MBRP, Outlook, Midland CB, more to come...
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:9/30/2005 16:36
I think the U codes are what are on the truck now if Im not mistaken, I think the V-s are what the 250's are running now...but the A codes Im not real sure on bud!! Hopefully someone else will chime in and help out!!!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
edited 9/30/2005 16:37
Saleen99122
• Somerset, NJ, USA
• Registered on 7/8/2005
• 32 posts
Posted:10/3/2005 11:28
Do a search on +spring +codes, there is a table out there that has all the info you are looking for.
I just did B's and V's on my 05 Ex with the V-10, and the front lift was almost exact to the table.
http://forums.thedieselstop.com/ubbthreads/showflat.php?Cat=&Board=UBB9&Number=617635&Forum=f9&Words=height&Searchpage=0&Limit=25&Main=617635&Search=true&where=sub&Name=16893&daterange=1&newerval=&newertype=w&olderval=5&oldertype=m&bodyprev=#Post617635
edited 10/3/2005 11:34
Aug250
• Miami, FL, USA
• 76 posts
Posted:10/4/2005 11:21
tfalk, did you get any lift from the B codes?
Saleen99122
• Somerset, NJ, USA
• 32 posts
Posted:10/4/2005 14:34
Couldn't tell you, sorry... When I installed the B's, I also added a 1" helper.
Truck is pretty much level. I'm toying with taking out the helper and putting in the
4 inch blocks instead of the 2 inch blocks to see what it looks like. I have a set of
LandYot's radius rods here, haven't had time to put them in. I may put the 4's in
at the same time so I don't have to trim the stock blocks - I can trim these ahead of time.
Posted:10/5/2005 14:39
tfalk! I'll take the 2" blocks off your hands (for $$ of course) if you don't think you'll ever use them again.
Aug250
• Miami, FL, USA
• 76 posts
Posted:10/11/2005 09:42
Are the B codes softer than what I have on there now or no?
Saleen99122
• Somerset, NJ, USA
• 32 posts
Posted:10/13/2005 07:36
Thanks Monsta, I'm going to hang on to them for a while. I still haven't decided if I'm going to
keep the Ex or not. If I decide to sell it, I will probably put it back to stock.
Aug, I can't tell you if they are any softer than what you have... My Ex had CCGG springs before.
I don't believe I got any lift from the B springs, if I did, it was minimal. I just removed the
1" helper, swapped the 2" blocks for 4" blocks and installed the radius rods. Still haven't
been able to get time to get it on an alignment rack with all the changes. I can tell you this,
the back is a lot firmer than it was, and the truck doesn't jump sideways on bumps anymore.
I still have a bit of wandering, and I'm pretty sure it's alignment related. I'll post the height
changes in a couple of days... right now, I'm trying to get my other toy put back together
so I can do some racing this weekend (if it EVER STOPS RAINING!!!)
edited 10/13/2005 07:40
