Brake pedal noise??
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 314
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:10/2/2005 22:38
Anyone have a problem with the brake pedal making a squeaking type noise when you push it. This is not a brake issue. it's the pedal itself. Appears to be in the area of the rubber boot. Has anyone had this problem, and if so, how do you fix it???
David
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:10/3/2005 19:54
White lithum should lube everythign up well, vasaline will work too, especially if its just a lube issue. We use petroleum jelly on alot on the aircraft, the yolk boots sqeak alot, and we quiet them up that way. Hope this helps!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Brake pedal noise??
