HELP!!! SUSPENSION SUCKS!
Thread Statistics:     Users to Post: 8   |   Total Posts: 19   |   Total Views: 3336
Posted:10/25/2005 14:59
Guys, are your airbags providing additional lift to the rear when NOT towing?
I want some rake on my truck...maybe a couple o' inches.
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:10/25/2005 18:04
Ummr-surprised Landyot did not suggest these--he has too much humility to brag on his invention. He fabricates radius rods--neat little invention that prevents spring wrap and thus the pot hole-bang - lets go in another direction scenario. As landyot has explained before--the leaf springs have a spacer to connect the springs to the axle. They use the spacer since the weight on the rear of a F250 is not near that of the X. The extra distance allows more torquing of the rear axle on the springs...so you bang pretty hard--to the point you feel like the X is jumping in another direction. Also I would highly reccomend a Helwig anti sway bar. These two additions improved my ride quality 100%. I don't know about the airbags but a thought might be that the airbag is raising the body to a higher position relative to the axle--like another spacer. I would theorize that this would make spring wrap worse.
Hope this may be helpful.
David
jscarb2
• MANTEO, NC, USA
• Registered on 10/25/2005
• 10 posts
Posted:10/25/2005 22:58
yes the air bags give you lift when not towing if you leave some air in them. i can go as low as 10 psi and be level instead of sagging. never go below 5 psi.
have not got my radius rods yet but they are coming!
jscarb2
• MANTEO, NC, USA
• 10 posts
Posted:10/25/2005 23:09
just checked ride-rite.com min. pressure is 5 max is 100psi for 2wd excursion rears. i put 80 in mine once and looked like i had lifted the back and lowered the front they lift probally 3 inches if you go 80psi or more. at least mine did. when i run 55 psi for towing the truck sits way jacked up after i take the trailer off!
Posted:10/26/2005 15:04
Thanks for the "plug," but when I read his description of the problem, it didn't sound like he was describing the reverberation in his tail end that's common to Excursions. Sounded more like a single bang to me. And that sounds like things are making contact when they ought not to. While I'd like for him to get a set of radius-rods, I don't think that is the solution in this particular scenario.
edited 10/26/2005 15:04
Toobsluver
• Waretown, NJ, USA
• Registered on 10/24/2005
• 34 posts
Posted:10/26/2005 15:24
Radius rods? What are these I keep hearing and what do they do? Got any pix on a website?
Luke
White 2000 Ford Excursion
7.3 PSD 4x2
Super Chips Super Tuner
K&N Filter
4inch turbo back exhaust from Magna Flow
(Soon to install Hellwig Rear sway bar)
Air-Lift Heavy Duty Air Bags
Fun Stuff
PS2, 1200 Watt Amp, 2 12' subs in the barn doors. Pioneer Avic N2 Navigational DVD player. 2 Flip down rear monitors. Second row captains chairs.
http://home.comcast.net/~punisherracing
Posted:10/26/2005 15:26
Check out "Must Do #5" at the following link:
http://www.supermotors.org/clubs/fordexcursions/articles/article_2/index.php
And you can see some more photos in my gallery. On the downside, I recently stopped accepting orders for the current production run, and won't be offering them again until March or April of '06.
edited 10/26/2005 15:28
Posted:10/27/2005 15:38
Sounds like you need to hire some help!
Posted:10/27/2005 17:59
I'm already farming out a good portion of the work to a retired coworker. Without him, I'd really be swamped. He really appreciates the jigs & fixtures I've made 'cause it makes his job easier. I use eleven different jigs & fixtures to build a GEN-II r-rod kit.
edited 10/27/2005 18:00
