New toys & install articles coming soon
Thread Statistics:     Users to Post: 4   |   Total Posts: 7   |   Total Views: 634
Posted:10/30/2005 01:03
Been busy lately with installing new toys...
What's done (install articles coming this week):
- Dieselsite braided electronic shift on the fly (ESOF) lines to replace rubber lines
- Dual Optima Yellow-top D34 batteries
- AFE Stage II Intake & ProGuard Air Filter
What's waiting to be done (install articles coming in November):
- Dieselsite external coolant filter kit
- APC headlights & corner lights
- Dieselsite high-pressure oil crossover line
- Dieselsite 203-degree thermostat & billet housing
- Coolant flush & new Evans coolant
- Autometer Trans temp, boost, and pyro gauges
Eddie Henson
• Cordova, TN, USA
• Registered on 12/8/2004
• 122 posts
Posted:10/30/2005 01:44
Looking forward to the article for the coolant flush and Evans coolant refill. Got the Evans coolant in my garage waiting for a chance to flush my cooling system. By the way, did your battery light ever go out? Also gauges are in the near future as well, so that will be helpful too. Thanks.
Eddie Henson
Posted:10/30/2005 15:24
Eddie,
I should be able to get to the Evans coolant swap in 2 weeks.
Unfortunately, the battery light is still on. No idea what is causing it.
gawent
• Registered on 3/2/2005
• 65 posts
Posted:10/31/2005 07:37
My light comes on intermittently. Usually after I first start it in the morning and until it warms up it stays on. Then it will go of when I get the RPM's up. It has done this since I bought it and have never had an issue with starting or anything. Usually worse when it is cold out. Actually it kinda had me concerned this morning because it stayed on extra long during my drive in to the office, but as usual, it went out and stayed out. I am not quite sure what to do about it.
Posted:10/31/2005 09:31
Mine flickers in the cold weather when I first start driving it. Seems to be affected by the RPM but within a mile, it stays on solid.
edited 10/31/2005 09:31
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:11/1/2005 20:18
Are the yellow tops the deep cycle ones? Im not sure which Im going to go with...
Thanks in advance!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Posted:11/2/2005 00:02
Thanks in advance!
Scott -- yes, the yellow tops are the deep cycle batteries. Perfect if you have an aftermarket stereo with amps (like me). The amps can drain "normal" batteries pretty quickly if you're just listening to the radio without the vehicle running. When I'm out in the garage, I typically listen to music from the X...haven't tried it with the yellow tops. The OEM batteries were good for about 1 hour tops...then they'd be drained too much to be able to start the X.
