reverse sensor problems
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 651
JLMBIGX
• Desmoines, IA, USA
• Registered on 7/4/2006
Posted:7/6/2006 17:51
when i put my x in reverse the reverse sensors turn oss automaticly i just put 4 new sensors on and still the same thing happens anyone have any suggestions and does anyone know were the brain foe the sensors is located??
Posted:7/6/2006 22:21
I have the same problem (although I have not replaced any of the sensors). Look forward to seeing the responses on this one. Mine's been broken for well over a year.
Posted:7/7/2006 11:03
The problem could lay within the PAM but one way to eliminate it to put a code scanner on your truck to be 100% sure.
If it is the PAM #B1342 will be the DTC
The PAM itself is located behind the rear jack storage panel.
Typical sources of a continuous tone;
Dirty or iced over parking aid sensor(s).
Parking aid sensor.
Parking aid sensor bezel(s) or parking aid sensor(s) locked into the rear bumper incorrectly.
Parking aid sensors are not aligned correctly.
False detection from parking aid sensor
edited 7/7/2006 11:06
