HELP! My X just stalled on the FWY!
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 548
Ace
• Malibu, CA, USA
• Registered on 10/27/2005
• 54 posts
Posted:8/1/2006 16:33
Was driving home from work the other day and my X stalled while driving on the freeway, luckily it was in traffic. But then it did it again driving at about 50 MPH, scared the sh*t outta me...Any idea what this is?
Eddie Henson
• Cordova, TN, USA
• Registered on 12/8/2004
• 122 posts
Posted:8/1/2006 19:10
Hey Ace,
what year model is your Excursion? If it has a 7.3L diesel engine, I'd suspect the CPS is going out on you. Let us know what year model and any other mods you've done. May help narrow down the problem. Good luck
Eddie Henson
Posted:8/1/2006 19:20
Sounds like a classic case of the Cam Position Sensor going bad, as mentioned above. See this article for how to change it out: http://superdutydiesel.com/wiki2/tiki-read_article.php?articleId=36
Make sure to use a 1/2" ratchet with a 6-point socket when removing it.
Ace
• Malibu, CA, USA
• 54 posts
Posted:8/2/2006 12:17
2002 7.3L x limited 4x4 no mods on the engine, except optima batteries. I do have an extended warranty, just want to know what it is before I take it in, to see if it's covered.
edited 8/2/2006 13:29
