Transmission Failures (please recommend)
Thread Statistics:     Users to Post: 7   |   Total Posts: 7   |   Total Views: 1348
MAGNA-MATIC
• Waldo, WI, USA
• Registered on 10/25/2006
Posted:10/25/2006 14:21
Hello All,
I have a diesel Ford Excursion (2001) about 3 weeks ago i just had a ford dealer install its 3rd transmission. I purchased the Excursion new first transmission died at 90k miles and the 2nd died at 135k miles. I'm quite disgusted with constant replacement, and its cost. I however found out that ford remanufactured transmissions and engines now have a 70k warranty vs the earlier 32k warranty. While this is an improvement it is after the fact.
Does anyone know why they fail? I have heard about installing larger aftermarket transmission coolers - is this a solution? Is there a better transmission out there to use? Should i have a temperature gage installed to moniter the transmission temperatures.
Any advice would be appreciated. Thank you,
Posted:10/25/2006 15:53
In the stock 4R100 transmission they generate alot of heat and one way to help lower the temps is by upgrading the stock fluid cooler to the V10 cooler as it's quite larger or purchase one used in the 6.0L Powerstroke trucks as they're the largest and basically bolt in with some adapting of the fluid lines.
Secondly upgrade the valve body to one such as the Factory Tech Valve Body (FTVB) which will benny lower fluid temps and more positive shifts in between gears.
Doing those two upgrades will extend the life of transmission and make driving the truck alot more enjoyable.
edited 10/25/2006 15:54
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:10/25/2006 21:24
Or get the BTS trans and forget that it has broken before and be happier still
Posted:10/26/2006 06:48
My first trans died at 87K. I had a Ford remanufacturered transmission installed to replace the dead one. I have about 88,000 on my remanufacturered trans. I've done the following improvements to help extend the life:
Dieselsite External Transmission Filter Kit Installation
Factory Tech 4R100 Valve Body Installation
I also have installed a transmission temp gauge to monitor temps and notice that my trans runs hotter now that I've moved down to the south (I used to live in MN). I have a transmission cooler sitting in my garage that I've been meaning to install, but just haven't gotten around to it.
Good luck,
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:11/14/2006 22:24
Interesting-my V10 transmission failed at exactly 87K. One of the clutch plates had a vertical crack--the rest was noisy!
59Excursion
• Falls City, NE, USA
• Registered on 3/19/2007
• 14 posts
Posted:1/3/2008 07:56
I've got the trans cooler out of my 2000 Ex V10 that I could sell if someone needed one. I swapped everything out for a cummins engine so I have alot of parts laying around.
2000 Excursion 4x4 - Planning to swap in a 5.9 cummins soon!
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:1/3/2008 11:53
What are you asking for it?
Kevin Curry
[email protected]
http://www.texas4x4.com
