What are those thingamajiggers called?
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 708
Posted:1/21/2007 22:51
For those of you who have replaced your rear Excursion shocks...
There are 2 bolts on the top of the rear shocks that screw into a removable threaded bolt-hole. What are these threaded things called? I need to get a couple of them at the parts store, and since mine have fallen out, I can't bring one in to say "I need this." I would rather not remove one of the other ones on the other shock in my X. It's where these bolts thread into (shown in this blurry picture I took a few years ago when I was doing a rear shock swap):
NASCAR-Mike
• Richmond, VA, USA
• Registered on 9/14/2005
• 20 posts
Posted:1/22/2007 06:27
I have always known them as bolt clips.
You should at least bring a bolt so you can match the thread. I think it may be metric.
2005 Ford Excursion Eddie Bauer 6.0 diesel
1996 Ford Crown Victoria P74
1994 Ford Mustang GT 5.0 SUPERCHARGED
Posted:1/22/2007 06:28
I have a couple spare bolts that I will surely bring. "Bolt clips" is what I'll tell 'em and I guess I'll wait to see their reaction.
NASCAR-Mike
• Richmond, VA, USA
• 20 posts
Posted:1/22/2007 06:37
At Autozone they have rotating rack in the nuts/bolts aisle that carries fender clips. These are basically the same thing, you just need to match the thread.
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:1/22/2007 08:17
Just go to your Fraud Dealership and order 4 of them.
housedad
• mt royal, NJ, USA
• Registered on 10/8/2005
• 88 posts
Posted:1/22/2007 08:45
The clips you will need are 8mm. Lowes, autozone, Pep Boys, Advanced, A really good local hardware store, any of these should have them. They are called clip nuts. I got a new set at Lowe's. If you can find them in stainless, so much the better.
Replace the bolts, also. You will want Grade 10.9 8mm X 25mm long bolts. 2 per shock.
