V Code and Front Hitch install pics
Thread Statistics:     Users to Post: 5   |   Total Posts: 9   |   Total Views: 761
housedad
• mt royal, NJ, USA
• Registered on 10/8/2005
• 88 posts
Posted:1/31/2007 16:28
Here is some pics of my install
V code Pictures
I have not had time to put captions on them yet, so I guess you'll have to use your imagination.
The reason this method was chosen was that I wanted to have Factory fog lights and still have a front hitch. Curt made a front hitch that went under the skirt for the 2003 and previous years. Ford changed the blockerbeam and front springhanger design in 2004, and so I bought the parts and basically turned the front hangers and blocker beam into a 2003. It all bolted up without a problem.
Now to install the fog lights. Another story.
Hope you enjoy.
Posted:1/31/2007 17:08
Nice job there House! I'm very familiar with what it takes to labor the job and at the same time photograph it all or as much as possible
Is your X Diesel powered I don't recall
Posted:1/31/2007 18:05
Nice job. I too want to do the front hitch and do away with the factory tow hooks (and put fog lights in their place). I like the Hidden Hitch application. It would block the OEM trans cooler so I also have an aftermarket trans cooler that I will install this spring. Right now tranny temps are just fine...the NC summers are a killer on the trans so far. Much different climate down here compared to MN.
Blocker beam is definitely different on yours compared to my '00. Interesting.
housedad
• mt royal, NJ, USA
• 88 posts
Posted:1/31/2007 18:35
Thanks for the compl;iments, guys. It was a PITA, but the results were worth it!!
My Ex is a 2005 V-10.
Posted:2/1/2007 20:27
I was very sore the next day after installing my V-codes. Laid on the couch, drank beer, and watched football.
housedad
• mt royal, NJ, USA
• 88 posts
Posted:2/1/2007 20:52
I hear ya! It hurts!
I did the V codes and front on Saturday and the modified B codes on Sunday. Nobody around to help. Then, after I got the rear spring packs assembled and the axles on, a friend showed up to put the rear tires on. (after all the real work, of course)
Monday I did the same thing as you, just with Ibuprofen instead of beer. (wish I could drink beer)
All I got to say is thank God for air tools and a come-a-long!
Age DO tell !!!
By the way, I have some captions up now on the pics.
caddys83
• Oklahoma City, OK, USA
• Registered on 12/4/2004
• 127 posts
Posted:2/2/2007 22:57
That is neat!
I've decided that Xochi was in cahoots with the gas stations to rid me of my bank account. I still and love her.
Aug250
• Miami, FL, USA
• Registered on 4/15/2005
• 76 posts
Posted:2/9/2007 12:54
What Mod is done to the B codes?
2005 EX 6.0 4X4 EB, 3" DR, 33" MT ATZ's, Landyot RR, Hoodblanket, Weather stripping mod, Zoodad, MBRP, Outlook, Midland CB, more to come...
housedad
• mt royal, NJ, USA
• 88 posts
Posted:2/9/2007 16:49
I took out the second from the bottom leaf from the original springs, and installed it with thin nylon shims between the B code 4 leaf pack and the thick bottom bed leaf. This increased the rate of the B code spring somewhat, but the length of that leaf still allowed the pack to go into reverse bend as the B codes are designed to do. I did not use the Excursion thick interleaf shims, as they will cause stress risers in the main leaf on the B codes. It is only safe to use the thin shims.
I did a long post on my reasoning in another website forum. The link is below:
http://forums.thedieselstop.com/ubbthreads/showflat.php?Cat=0&Board=UBB9&Number=3199362&Searchpage=1&Main=3192673&Words=+housedad&topic=&Search=true#Post3199362
