Sits Lower on Left Side
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 670
timsexcursion
• Northeast, VT, USA
• Registered on 2/8/2004
• 27 posts
Posted:2/7/2007 09:24
Okay, I'm not that heavy, but I noticed that my PSD Excursion sits 3/4 of an inch lower on the driver side in the front measured to the bottom of the fender. I need to replace my front leaf springs and took some measurements. I also have seen where front springs have been replaced with a stronger spring on the driver side. Anyone else seen this? I can provide a link if I can find it.
2000 Ford Excursion 7.3L
Superchips 'Tow Safe'
K&N Air Filter - Stock Airbox
Tru-Cool 4490 Trans Cooler
Pharmer
• Mackinaw City, MI, USA
• Registered on 12/19/2002
• 52 posts
Posted:2/7/2007 19:24
Check over at thedieselstop, search under PSD Excursions. You should replace with Ford superduty springs U or V code. The U will give a lift around 1.5 inch and the V slighlty more. I've heard of using the V on the drivers side due to extra weight on that side and U on the right. They are very close in rates.
I used the U code on my old V10 Ex and got a lift of 1.5 inches, the ride was greatly improved. I plan on upgrading the springs on current PSD Ex with the same when the weather warms up. See pictures in my gallery of 2000 Ex with U codes.
edited 2/7/2007 19:25
Posted:2/7/2007 22:44
I did not have the uneven problem on my X, but I just swapped out my factory front springs (after 176,000 miles) and installed V-code springs. It's even on both sides.
Here's the install:
http://www.supermotors.net/clubs/fordexcursions/vehicles/registry/9/54681-2
timsexcursion
• 27 posts
Posted:2/8/2007 00:38
Yeah, thedieselstop is where I got my info and wondered if anyone else had the 'lean' problem...
Pharmer
• 52 posts
Posted:2/8/2007 13:56
I think most sag at about 50 K miles and the drivers side is a little lower.
Soaggydogg
• Little Rock, AR, USA
• Registered on 3/5/2007
Posted:3/5/2007 11:03
My parents 03 7.3L had the uneven stance and dad put V on one side and U on the other. I think it evened it up or made it real close. Bruce is the best to ask when it comes to springs and research. My 2002 already had V code springs on it and it is level.
