Synthetic Oil?
Thread Statistics:     Users to Post: 8   |   Total Posts: 9   |   Total Views: 1244
RussellExcursion
• Los Angeles, CA, USA
• Registered on 4/4/2005
• 33 posts
Posted:2/20/2007 17:15
What is the consensus on using synthetic oil in the Ex?
My next oil change will be this April so I would like some feedback from those who have made the switch.
Russell
Oil-Pig
• Sheboygan, WI, USA
• Registered on 11/17/2005
• 52 posts
Posted:2/21/2007 16:25
I use the Rotella Synthetic especially in winter. Once in a while I will swap out a gallon of Synthetic for the regular rotella. But in winter I run straight Synthetic.
I look at it this way. Sure the Synthetic is more $$ but its still around the cost of a fillup and it lasts 5000 miles. I don't know how much better it is in reducing friction but I do know it blows away dino oil with temp extremes. When its 10 degrees out the Synthetic is still flowing.
Just my thoughts.
I'd rather be in the boat with a drink on the rocks then in the drink with the boat on the rocks.... But either way theres gonna be a good story!!!
Posted:2/24/2007 11:56
I run Amsoil 5W-30 Heavy Duty Diesel synthetic oil for the last 140,000 miles. I change filters every 5,000-7,500 miles and change oil every 10,000-12,000 miles. I also use Amsoil oil filters, too.
absolutezero273c
• Toledo, OH, USA
• Registered on 4/9/2004
• 81 posts
Posted:2/28/2007 21:02
I've been using Chevron Delo Synthetic 5W40 since I got my Ex. I switched to synthetic almost 10 years ago when I was doing a lot of highway driving in my Jetta TDI. Less blow by and consumed less oil at highway speeds. I have the peace of mind knowing I will have the oil flowing a little easier in the winter and less high temp degradation or breakdown in the summer.
2001 Flagstaff 829-BHS
poormonkey
• Chicago, IL, USA
• Registered on 7/27/2004
• 59 posts
Posted:3/1/2007 12:03
I run the Rotella year round. I change it myself and I buy the oil and filter from Walmart. About $70-80 for the oil and the motorcraft filter. I have noticed the price fluctuates a bit. I figured changing it every 5k-6k miles, it is worth the invesment in the syntehic.
Speaking of oil, anyone use a oil filter wrench that grabs the oil filter on the end and then you connect a socket wrench to it? I can't find one large enough for the filter, and I am tired of scraping my knuckles when using the traditional wrench that wraps around the filter.
2002 Excursion 4x4 7.3L
superduty59
• Carmel, IN, USA
• Registered on 3/2/2006
• 19 posts
Posted:3/3/2007 06:56
Bought one at NAPA a few years ago that fits 1/2" ratchet. Works great and have had no problems.
Oil-Pig
• 52 posts
Posted:3/3/2007 11:28
If you don't crank the filter on tight you should be able to remove it by hand after 5000 miles. I run my filter on till the gasket touches then give it another 1/2 turn. I have never had it fall off or leak and all it takes is my hand to loosen it. Now anytime I help a buddy out that had a quick lube place do the oil changes before I can barely get the filter off using any method known. I think the quick lubes put them on with an impact wrench
jnyost
• Mount Vernon, XX, USA
• Registered on 3/5/2007
Posted:3/5/2007 04:45
I too use Rotella Synthetic and usuall go around 10k per oil change.
Jared
Douglas Dircks
• New Richland, MN, USA
• Registered on 11/13/2003
• 118 posts
Posted:3/21/2007 18:39
Have been running Rotela Syn. in the X from 130K-171K miles and change oil every 15-20K miles. The F250 has had conventional oil every 8-10K miles, 236K miles.
The Excursion is total syn. and the F250 is except the motor which I'm just going to stick with the conventional oi.
Synthetic Oil?
