sound from rear-end, like a bad diff
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 455
• 0 posts
Posted:6/6/2003 14:46
Low speed turns, apply throttle and it sounds like the limited slip is grabbing harder on one side than the other. I would guess the clutch pack is beginning to go, its only under a load, not while coasting. Any one else have early issues with a 10.25 sterling full floater? I would assume sterling is bullet-proof, but I guess it could have its flaws. Any advise?
Posted:6/7/2003 09:53
The sterling rearends are bullet-proof...limited slips are not. The limited slip can be replaced if it is going bad -- how many miles do you have on the vehicle? Is it under warranty?
• 0 posts
Posted:6/9/2003 13:43
It is out of factory warranty, and it appears to be the limited slip. Upon learning more about the 10.25, I have been told by diff specialists that using the ford synthetic viseon fluid can help stop clutch chatter from the limited slip. So, it looks like i am just going to have the LS re-built because its soo cheap once they are in there already.
