new shift kit from TransGo
Thread Statistics:     Users to Post: 4   |   Total Posts: 8   |   Total Views: 1325
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:1/23/2003 12:14
TransGo has a new shift kit out,only certain shops have them now.this kit is for people that like to use the manual low a lot.its aimed at the PSD but will help any model 4R100 or E40D.the name of the kit is TowMaster.i will be installing 2 of them here very soon.you guys are going to like it.
regards, mike
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:1/23/2003 14:29
Do you pull the tranny out of the truck like the other Trans Go kits? That can make trans go a little expensive.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
gearman
• 336 posts
Posted:1/23/2003 14:55
the trans is pulled for two reasons when the shift kit is installed;a .060 hole is cross drilled in the pump to leak line pressure into the lube passage(torque converter and cooler line passage).this give the torque converter an extra charge resulting in 10% more lowrange and midrange torque.it makes a seat of the pants difference.it also increases the oil flow through your cooler lines by 200%.we also open up the lock up passage to give better clamping power to the converter clutch.on 4R100s,it alows us to install the TransGo lock up valve which converts that system to an on and off system.as it is now,all 4R100s use a pulse on pulse off(which means it slips the clutch on and off)not good for towing.the rest of the kit installs from the bottom and is very beneficial for longevety.pulling the trans and doing it right will give you a performance upgrade you can really feel.
mike
MONGO
• Sandwich, IL, USA
• Registered on 1/3/2003
• 210 posts
Posted:1/23/2003 16:50
Hey Gearman, I wish you where in Ill. I`d give you alot of work! I don`t know anybody around me I would trust Still search`n.
Posted:1/23/2003 18:50
regards, mike
Mike,
Know what the pricing details are? Does this replace old shift kits or is it an additional model?
gearman
• 336 posts
Posted:1/23/2003 20:53
Eric
i dont know the price yet,i got two kits UPS with no bill(Suncoast and BTS,eat your harts out.LOL)the new kit has more valves to compensate pulling the trans in manual low.we in the trans business always thought pulling a trans lever down to L(low)meant increase pressure.not so with Ford.pulling down to L in many 4R100s brings trans mainline pressure to 37lb.you dont want to hook up to anything big the new kit fixes these problems,also helps PSDs with exhaust brake which can grenade a trans quick.i would think that the kit will go for 150.00 retail(there is no price yet).you are paying for some very high tech,i was not involved with this development,but was privy to the development of it as were Suncoast and BTS,and i hold these two establishments in the highest regard.i use Suncoast converters in my shop
regards mike
gearman
• 336 posts
Posted:1/23/2003 21:04
MONGO
i know what you are saying.i have had the same problem sending my customers to good mechanics that wont just throw money at the problem at the customers expense.seems the basic idea of most techs (i use that word lightly) is if we replace everything under the hood,it should work.most problems we have found is bad ground to the computer,or intermittant loss of 12V to trans because the trans shares its voltage with a bunch of stuff under the dash board.
i think i am ranting,have to stop this,sorry
mike
gearman
• 336 posts
Posted:1/24/2003 09:16
Eric
sorry i missed the second part of your question.the new kit is an updated version of the old one.it was developed for the diesel with exhaust brakes and is very beneficial to all E40Ds and 4R100s
mike
