does this seem right to you guys
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 440
offroadjunkie
• middletown, DE, USA
• Registered on 9/7/2002
• 43 posts
Posted:7/9/2003 16:49
check the link. the lift discription says a 6 in lift will fit 37s
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:7/9/2003 17:11
where is the link? ? ?
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
offroadjunkie
• 43 posts
Posted:7/9/2003 19:42
http://www.central4wd.com/store/itemdetail.asp?ID=7951
Posted:7/9/2003 21:07
Seems right to me. Hopefully MrRottnDog chimes in with his infinite suspension lift wisdom.
Weatherlite
• Mountain Home AFB, ID, USA
• Registered on 10/21/2002
• 133 posts
Posted:7/10/2003 12:20
I would have to say that that is accurate as well. I've seen several pics of 37's with only a 6" lift. I have the 37's and the lift but I haven't installed it yet. I measured everything out even compensating slightly for spring compression etc and sure enough, it fits. Now at full compression to the bump-stop with the wheel turned full lock it will rub but otherwise should be fine.
Just my .02
Mikie
