what rears in the x
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 586
offroadjunkie
• middletown, DE, USA
• Registered on 9/7/2002
• 43 posts
Posted:9/8/2003 16:23
what rears are in the 2000 x. dana 50? 10.25 or 10.50?
Posted:9/8/2003 22:07
Sterling 10.50.
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:9/9/2003 10:17
dana 50 is in the front till this yr. then dana 60
On another note Ford's website was showing numbers for the first quarter and the eXcursion was up 33% over last yr. Thats us previous X owners getting the last of a dying breed!!!
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
offroadjunkie
• 43 posts
Posted:9/9/2003 16:10
thank you
anyone have their gears changed and how much did it cost?
edited 9/9/2003 16:12
Posted:9/9/2003 17:04
thank you
A couple years back I spent about $400 (or so) to have new gears installed in the front axle dana 44 on my Bronco. It was a low price because I was able to bring the 3rd member in for them to setup the gears. I also had a lockright locker put in which is a no-brainer to install.
$1500 that you mentioned in a previous post sounds pretty good considering they have to setup the gears with the axles installed on the truck. I assume this price includes all parts.
You can always do just the rear first and not use 4x4 for a while if you cannot afford it all at once. I did this with my Bronco when I swapped out the 8.8" rear for a dana 60. I didn't wheel it for a month and just drove it around town to break in the gears. I upgraded the gears in the frontend about a month later.
what rears in the x
