SuperFord.org Forums
SFO Forums > SuperMotors Community Discussion > General F/L/M
Leaking Pressure Line on Ford Countour Power Steerign
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 598
Danielle Shrader-Frechette
• Seattle, WA, USA
• Registered on 2/11/2003
Posted:2/11/2003 16:04
Anyone know of a good mechanic in the south Seattle area? I'm getting what i think is an exorbitant price of $650. The hoses are less than $100 at napa and I think $550 in labor is a bit stiff for replacing three hoses. Any thoughts.
D
• 10
Posted:2/11/2003 19:38
Danielle,
What does an hour cost for shop time in your area? That would be nearly 12 hours of work here in MN. Did the mechanic explain the procedure involved in replacing the line? Unfortunately I am not familiar with the placement of the power steering lines on a Contour. Regardless, 10-12 hours does seem excessive.
David Sickles
• Houston, TX, USA
• Registered on 11/19/2002
Posted:3/20/2003 20:14
go to contour.org they seem to know alot, someone there could probably help you they have helped me in the past! good luck!
David Sickles
• Houston, TX, USA
Posted:3/20/2003 20:15
www.contour.org
