Front Passenger Side Clunk?
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 476
JackB
• Prairie, WI, USA
• Registered on 2/16/2003
• 11 posts
Posted:2/16/2003 05:41
OK, one more question. I test drove a 00 V10 limited and over certain bumps, perhaps more so when turning left, I occasionally heard a clunk which sounded like it was coming from the passenger side front. I was just wondering if this might be indicitative of the suspension or some other problem I might want to check out before purchasing.
The vehicle has 54K miles, is a 00 V10 Ltd. I didn't see any signs of body repair in or around the right front but I did notice some writing in black marker on the wheel mostly covered by the hub. I thought that was a little weird and wonder if it's a replacement wheel.
Any thoughts would be appreciated. Thanks!
Posted:2/16/2003 08:35
Jack,
The clunking sound you hear over bumps is one of two things (well, maybe both!):
- Loose body bolt. Simply have it tightened and the problem will go away. Pretty common on '00 X's.
- Front sway bar linkages need lubrication. Have them lubed and the problem will go away. Also pretty common on X's of all years.
Good luck with the decision.
