SuperFord.org Forums
SFO Forums > Site-Related Forums > SFO News and Feedback
Picture albums
Thread Statistics:     Users to Post: 2   |   Total Posts: 5   |   Total Views: 537
A91EBexplorer4x4
• Memphis, TN, USA
• Registered on 1/14/2003
Posted:1/14/2003 22:57
im trying to figure out why when i upload a pic it just puts up a red "X". i reduced the file size to 47KB but it still wont let it post for some reason. does the actual picture size have to be reduced?
[b]"If it wasn't for bad luck, I wouldn't have any luck at all !! "[/b]
• 10
Posted:1/14/2003 23:04
Howard,
The server will accept a file size up to 20 megabytes.
The reason you're experiencing a problem is most likely due to the fact that you are uploading the file with an incorrect file extension (it should be .jpg or .gif -- nothing else, no spaces after it, etc.) or you're attempting to post a non-supported image format like a .bmp.
Does this answer your question...?
A91EBexplorer4x4
• Memphis, TN, USA
Posted:1/14/2003 23:19
well the file is a Jpg file. i go to load it and browse go straight to the file and then do send files. then it shows a red "X" below it.
• 10
Posted:1/15/2003 00:40
Howard,
Looking at your registry entry, the broken image that's currently posted has a filename of "t_Jan12". What you need to do in order to get the posting to work is to add ".jpg" to the end of the file name. In other words, your filename needs to be: t_Jan12.jpg
A91EBexplorer4x4
• Memphis, TN, USA
Posted:1/15/2003 01:55
ok looks like i got it now.
Thanks.
Picture albums
