Anyone know what this is?
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 1123
Dwayne Porter
• Ellsworth AFB, SD, USA
• Registered on 2/10/2004
• 22 posts
Posted:6/9/2004 13:18
Dumb question; does anyone know what the piece of equipment is that hangs down from what appears to be an exhaust system protection bracket underneath the middle of the truck? It's a roughly X-shaped piece having what appears to be rubber blocks attached and doesn't seem to be connected to anything important, just hanging out waiting to be busted off on a bad road.
Posted:6/9/2004 21:23
If it's directly in the center of the vehicle, I think you're referring to the counter balance that prevents vibrations from occuring.
dddenio
• Detroit Lakes, MN, USA
• Registered on 8/18/2004
• 41 posts
Posted:8/19/2004 16:18
Dwayne,
There should be 2 of them. 1 on crossmember below transfer case & 1 above driveshaft on crossmember. They quell some vibrations. If you remove em, I'll buy em. I have one bent already.
Dennis
Dwayne Porter
• 22 posts
Posted:9/6/2004 20:39
I only see one; its in the center of the vehicle towards the passenger side. Doesn't move around, just bolted to a bracket.
