Home/ Forums/ Car and Truck Make and Model Specific/ Bronco, Bronco II/ help with interior
Bronco, Bronco II
help with interior
2 posts 2 contributors 2,033 views
WJ
Will JonesOP
Jun 15, 2004 at 2:47 PM
Hey all. I have a 92 Bronco Eddie Bauer. The door panels and dash are "brittle" and make all kinda noise when you hit bumps. Where can I get replacements (dash AND door panels) Also, the truck came with a 3" lift and I wanna know if I can remove it and put it back at original height. It gets way too squirrely when you hit bumps at highway speed. Lastly, I have some weird noise that comes thru my speakers when I turn the engine off. Maybe my amp? Thanks for any help......
EL
Jun 16, 2004 at 12:30 AM
For Bronco interior parts, try Jeff's Bronco Graveyard (click on their link on the right-hand side of this page). Or go to http://www.broncograveyard.com
Anything can be removed. It will help to know if it's a 3" body lift or suspension lift (see my other post in response to this question about how you determine which type of lift you have).
Any noise coming through the speakers is usually the result of a bad ground. If you have an aftermarket amp installed, make sure that the connections are tight and that the grounds are solid.
