Black smoke
Thread Statistics:     Users to Post: 7   |   Total Posts: 10   |   Total Views: 1686
XMen
• Phoenix, AZ, USA
• Registered on 6/19/2004
• 18 posts
Posted:6/21/2004 19:36
New this site, and to diesel...I bought a superchip programer for My 04 X...Put on performance mode..WOW what a difference, but the black smoke from the exhaust, I could not see anything behind or beside me when I take off...Is this normal? everthing else is completely stock
Posted:6/21/2004 22:11
XMen, welcome to the site!!! You will love your diesel-powered X!
Black smoke -- yes, this is normal if you romp on the "Go" pedal, particularly if you're in a high-performance mode. Be careful not to get to be too much of a lead foot on a high-HP setting...you will want to do exhaust modifications to reduce exhaust temperatures sot hat you don't melt that precious turbo.
Enjoy the new rig!
Don Murray
• Bridgewater, NJ, USA
• Registered on 1/5/2004
• 132 posts
Posted:6/22/2004 06:29
Welcome,
the black smoke is actually unburnt fuel. As E. Long states you should have a bigger exhaust but also a bigger air intake. If you provide the engine with the means of more air to mix with the fuel, it will reduce the smoke and give you an additional 20+hp and lower EGT's. I have a Flip chip and even in 140hp mode not even a puff of smoke.
Be very careful when running the mode by itself. It will melt the turbo fan.
Don
aKa The TRACTOR
Smokem' if you can!!!!
XMen
• Phoenix, AZ, USA
• 18 posts
Posted:6/23/2004 08:32
Thanks for the input...I going to leave the X in the stock mode until I install the new intake and exhaust...This is addicting, I can't help myself...POWER..POWER...give me more POWER
beachbumcook
• DeSoto, KS, USA
• Registered on 8/10/2004
Posted:8/10/2004 19:55
Yes, deisels will put out some black smoke and more under WOT... but here is what you need to do.
1) Have dealer double-check motor for correct operation (which it sounds like you did).
2) Look at the short tailpipe on your Excursion compared to a diesel F250 or F350 (notice how it is short and inside the quarter panel)???
3) I had dealer/Ford pay for a chrome tip extension due to my concerns of a constant dirty quarter panel and unsafe exhaust flow which I said would come up from the underside of the quarter panel.
4) How can the F250 & F350 have longer tailpipes and be designed right and not the Excursion???
5) All is well now and my exhaust tip really helps, as well as looking good.
6) There is NO reason you should pay for their design and safety defect (in my opinion).
Good luck,
Jeff
2003 Excursuion 6.0L PSD
4X4 - LTD
Gen-X
• Toronto, XX, Canada
• Registered on 1/19/2004
• 344 posts
Posted:8/13/2004 19:44
Good luck,
Jeff
4X4 - LTD
Jeff can you post a picture of your exhaust tip. I would like to see what it looks like on the X.
Cheers
John Stewart
• Dayton, OH, USA
• Registered on 8/23/2004
Posted:8/23/2004 13:19
Please do not take your truck into the dealer with the programmer still installed. If they catch it they will more that likely void your warranty. Ford has been on a real mission lately to do anything that they can to avoid dealing with warranty issues with the 6.0 diesel.
This diesel preformance thing is a real addiction. Once you start you won't want to stop!
Posted:8/23/2004 13:23
I can confirm this. Had warranty repair voided when my transmission died because I had a chip installed.
Gen-X
• 344 posts
Posted:8/23/2004 13:56
It's true, Ford will make note of the installed chip and keep this data on file under the truck's VIN. This means your warranty is reduced/removed and the truck's resale it also lowered.
Not sure if other non-Ford car company would check against the VIN for this type of data. I would think so, because I tried to trade in a Ford at GMC after a small fender bench and GMC knew about it....I guessing because it was filed under the truck's VIN.?!?
edited 8/24/2004 15:20
FamilyRideII
• Flower Mound, TX, USA
• Registered on 8/7/2003
• 51 posts
Posted:9/8/2004 08:57
I also have the 1704 and yes, it makes lots of smoke in the HP tune. Still smokes pretty good with the Econ tune.
I'm at about 600ft and I've yet to see my egt's go higher than 1150* and that was wiht the HP tune and towing 7500# in close to 100* temps. The SC runs pretty cool but that makes sense when you feel where the power is. It's very conservative to say the least, on the low end meaning
2004 Eddie Bauer Excursion
4x4 6.0 PSD, all the goodies, Superchips 1704, Magnaflow, Isspro Gauges, 285 REVO's
Black smoke
