Vehicle height
Thread Statistics:     Users to Post: 5   |   Total Posts: 5   |   Total Views: 515
Pro68Camaro
• Houston, TX, USA
• Registered on 3/4/2005
• 8 posts
Posted:3/6/2005 22:15
I'm looking at a couple of excursions. My question is how high is the2 wheel and4 wheel drive versions? I will need to be able to clear in my work's parking garage. I see lots of Suburbans in there and they look to clear by a mile. The 2wd should be no problem, it's the 4wd that seems awfully high.
Posted:3/6/2005 23:11
Hello and welcome to the Excursion forums
All I can say is that our 4x4 will clear our 7' garage opening if that gives you an idea on clearance
Wayne Scrimshaw
• Redmond, WA, USA
• Registered on 1/23/2005
• 8 posts
Posted:3/6/2005 23:28
Welcome to the Forum!
I had the same question several weeks back before I pulled the trigger. My stock 2004 4x4 limited will fit in a 6'10" parking garage. If I recall correctly, our roofline is 6'8"
Hope this helps and welcome.
Wayne
Posted:3/6/2005 23:53
I have driven my 4x4 X (stock ride height/wheels/tires) in a 6'9" parking garage without problems. Just drive slow...anything lower and you'll probably have "issues."
Posted:3/7/2005 15:03
My company has three different parking garages within a couple blocks of each other. My stock-height 4WD Ltd will NOT fit in the 6'6" garage, but fits in the others (posted as 7') just fine.
Vehicle height
