Just bought Mineral Gr. 2005 Powerstroke 4x4
Thread Statistics:     Users to Post: 5   |   Total Posts: 6   |   Total Views: 562
Samski
• McKinney, TX, USA
• Registered on 4/11/2005
Posted:4/14/2005 21:33
What a pleasure this thing is to drive! It sure is a nice feeling knowing you have great power and all the room you need.
Quick question - I'm looking at getting a set of 18x9 wheels with 325/60's. I am not going to put a lift on it. I don't mind if they rub a touch when you turn short but has anyone had experience with this?
Any info is appreciated.
Thanks.
Posted:4/15/2005 09:19
Thanks.
Welcome to the club, Samski!
As for your tire/wheel question, can't tell you. I'm still running factory tires/wheels. Someone else with a lift will most likely chime in.
Posted:4/15/2005 10:46
Welcome to the Excursion forums as well Samski and Hello nearby neighbor
Those sound like a big pimpin wheel tire combo that I wouldn't know how to answer to unfortunately maybe someone will word up,the largest I've went to on an Excursion is 285/75/16's
200Proof
• Houston, TX, USA
• Registered on 10/9/2004
• 28 posts
Posted:4/16/2005 01:07
A lot of it will depend on the off-set of the new wheels. I had 305/70/16 installed on the stock rims and drove the truck for a day before I had the 2" lift installed. I had no tire rub at all at the stock height, but againt that was with 33" tires, you're talking about 2" taller so you probably will get some rub.
I think you are going to find that the 325's are going to look kind of "crammed in" the wheel wells with no lift. Even with 305's I think the tires looked to tight in the wheel wells, the truck looked much more proportioned when I added the 2" lift. But that's just my oppinion
2004 Excursion Limited - Black, 6.0 PSD, 4x4
3" Donahoe Racing lift w/ B code rear springs, Pro Comp Xtreme Alloy 6005 wheels & 315/70/17 tires, Donahoe Racing Signature series shocks, Rancho steering stabilizer, Landyot Radius Rods, 30mm rear sway bar, billet grill w/ black Ford emblems, Prodigy brake control, K-40 front & rear radar detector, Eclipse AVN5495 Nav/DVD w/ back-up camera, PAC Steering wheel Interface, Dynaudio 240 MKII components, JL Audio XR-650 CSi components, JL Audio XR-650 CXi, JL Audio Stealth Box 300w sub, JL Audio 450/4 amp, (2) JL Audio 300/2 amps, Clifford G5 alarm, SCT Xcal2 w/ Innovative Diesel Tunes & Edge Attitude Monitor
http://community.webshots.com/user/200Proof
Samski
• McKinney, TX, USA
Posted:4/16/2005 01:54
Thanks for the advice guys. I may have to do some testing on it first before I pull the trigger. I know I will have a lot more questions before it's said and done.
Erich
Mark Rychel
• Chesterland, OH, USA
• Registered on 3/10/2003
• 54 posts
Posted:4/18/2005 20:59
welcome,i love the color
Mark Rychel
