Back Window Struts
Thread Statistics:     Users to Post: 6   |   Total Posts: 25   |   Total Views: 4144
Michael Gail
• Sierra Madre, CA, USA
• Registered on 5/1/2003
• 138 posts
Posted:7/10/2005 21:59
I want to say a BIG THANK YOU to who ever figured out the the 4 by 2 has longer struts on the back window than the 4 by 4. I just replaced my struts with the longer set and sun-of-a-gun I can now stand up straight under the open window. I'm 6'2" and just barely clear but that's so much better than banging my head every time i'm under it.
Mike
'02 EX, Limited, 4X4 , PSD, Nitto, Terra Grapplers 295/16, K&N Air Filter, Billet Grill, Hidden Hitch. Magnaflow SS Exhaust system with 3.5" downpipe, 4" main and 5" tip. Banks Six-Gun Power Module, Banks TransCommand.
Posted:7/11/2005 07:02
Heya Mike,
The longer 4x2 strut info has been around at least since we got our X in June 2002,they are indeed a scalp saver for many owners
edited 7/11/2005 07:04
Posted:7/11/2005 07:55
When it's worse is when you wear a ball cap... that "hides" the hatch above the bill and ya fugitabout it and lean in to put something in the back
thought about hanging tassles ont he corners so I SEE them when the hatch is open
Posted:7/11/2005 09:25
I thought all Texuns wore cowboy hats???
Posted:7/11/2005 16:35
Oh yeah, that's what I meant !!!
And I have webbed toes from having the pleasure of being "reared" in Losing- Annie !!!
one of these days Eric !
ONE OF THESE DAYS !!!
POW, right in the kisser
edited 7/11/2005 16:36
Michael Gail
• 138 posts
Posted:7/11/2005 20:30
Heya Mike,
Yeah, I know. I have seen it from time to time. It just took me forever to order them. I never rememebered to do it when I was at the local dealer. This time, I was driving my EX to work and just stopped by on my way home. Next step is to get the larger exhaust. Hmmmmm..........
Mike
edited 7/11/2005 20:33
KevinsOffroad
• Phoenix, AZ, USA
• Registered on 5/15/2005
• 38 posts
Posted:7/19/2005 11:29
Can someone do me a favor and measure the length of either the 4wd or 2wd version? My lid is way too close to the Ex's lid, and I don't need to lose any more hair, particularly in large chunks.. I'm hoping that the previous owner installed the 4wd set.
Kevin
Posted:7/19/2005 11:57
Kevin our Excursion is not here to check the length of the struts but I can tell you the 4x2 struts are like 3" longer in length.
The 4x2 strut part number is Ford # YC3Z-78406A10-AA
edited 7/19/2005 11:58
Posted:7/19/2005 15:31
03 4x4 X is 14 7/8" from end of strut to end of strut as mounted....
Hope this helps !
KevinsOffroad
• Phoenix, AZ, USA
• 38 posts
Posted:7/21/2005 10:33
Does anyone have the 4x part number by chance? My struts are labeled as: YC35-78406A10-AE, and are about 14.5" extended from pin to pin. Just wanted to verify that there is a longer strut than 14.5" with the part number that Bill gave above. The only difference in the p/n is the fourth digit (5 rather than Z, which is close enough to be a misprint, maybe?) and then the last "E" rather than an "A". In ChryCo-speak, the letters at the end just means that they've revised that particular part in some manner several times, but not necessarily the length.
A little more research: Google gave me this link: http://forums.thedieselstop.com/ubbthreads/showflat.php?Cat=&Number=2457448&Main=2453538. Just past half way, Scotpart posts, "If you have the correct 2X4 struts, the glass on the lift gate will be parallel with the ground. " Well...mine is parallel with the ground, but the struts are 14.5" from pin to pin. I'm confused.
Kevin
edited 7/21/2005 10:42
Back Window Struts
