Recommend Good Greaseable U-joint for Rear Driveshaft?
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 1078
Richard Smith
• Knoxville, TN, USA
• Registered on 10/4/2003
• 104 posts
Posted:8/8/2005 09:34
Can someone recommend a good greaseable u-joint for the rear driveshaft of my 2003 V-10 Excursion. Maybe something better than the standard issue from Advance Auto, etc.
Brand, Source and Price?
Posted:8/8/2005 22:37
Dana/Spicer
I wouldn't hesitate to go with u-joints from auto parts stores, however. My offroad buddies inform me that they shy away from greasable u-joints noawadays because they are actually weaker due to the grease zerk.
If you really need a stronger u-joint, then you'll want to go with 1350's (1-ton ujoints). This will however require your driveshaft to be reworked to accept the 1-3/16" diameter ujoint cap. 1330's (3/4-ton ujoints) are a 1-1/16" diameter cap. (This is all of course assuming that the Excursions come with 1330's since they are a 3/4-ton suspension. I have not personally verified this.)
You'll spend anywhere from $20-30 for a quality ujoint.
Richard Smith
• 104 posts
Posted:8/9/2005 14:36
Thanks for the info. My current u-joints are 1-3/16 inch diameter caps.
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:5/18/2012 23:37
apology but i was just need urgently your advice for my u joints installation and where can i buy a discount auto parts for my 2003 v10.
edited 2/1/2013 20:39
