Ford Excursion Forums > Ford Excursion V8, V10, and Powerstroke > Article Discussion Topics
Official Optima D34 Yellow-Top Battery Installation Thread
Thread Statistics:     Users to Post: 4   |   Total Posts: 10   |   Total Views: 5750
Posted:10/30/2005 12:03
This is a thread for any further discussion on the "Optima D34 Yellow-Top Battery" article available at: http://www.supermotors.org/clubs/fordexcursions/installs/install_10/index.php
Posted:10/30/2005 13:32
Nice installation there Eric I bet the replacement Optimas may have fixed that gremlin you had recently
Posted:10/30/2005 15:20
Unfortunately, the battery light is still on. The Haynes manual I just purchased doesn't go into much detail on what could cause the battery light to go on and/or stay on.
Posted:10/30/2005 18:18
Outside of putting the code scanner on it I couldn't find anything in the service manual
darrell g
• detroit, MI, USA
• Registered on 12/6/2004
• 9 posts
Posted:10/31/2005 07:40
first time posting , i put in the yellow top about 10 months ago they are great but just now my light is coming on at idle. when you rev up to app. 2000 rpm it goes out but comes back on at idle again that was 2 days ago ,yesterday started hearing a loud knock from under hood upon investigation "the old broomstick trick" it sounds like it is coming from the alt. now this am x would not start . going to put a new alt. on today and charge battery. has anyone heard of this.
Posted:10/31/2005 09:35
Having just went through replacing my batteries and alternator, it sounds like your alternator is dead. It was most likely not putting out enough voltage at idle to keep the batteries charged, which is why the battery light went on. When you'd rev it, it would increase the output back to an acceptible range, and the battery light would go off.
Here's an install article on replacing the alternator. Pretty easy to do.
Let us know how it works out.
Oh yeah, welcome to the club!!
darrell g
• detroit, MI, USA
• 9 posts
Posted:10/31/2005 10:46
THANKS THE ARTICLE WILL HELP!! but have you heard a alt. knock like a rod?
Posted:10/31/2005 10:48
Anything's possible if it's bad. There are moving parts, so it doesn't surprise me. I've only heard grinding sounds.
darrell g
• detroit, MI, USA
• 9 posts
Posted:10/31/2005 12:53
as far as your light goes i think i heard somwhere about " resetting " it by connecting and disconnecting the ground cable 3 or 4 times and then letting it set 20 min. before hooking the ground cable back up?
Posted:12/26/2005 18:13
I had one make a continuous low-RPM sound (bearings failed from a too-tight fanbelt ... no, it wasn't on the X), and it was replaced under warranty. But a knocking sound? Makes me wonder if the casing has cracked.
edited 12/26/2005 18:14
