For those as obsessive as I.....
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 661
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:7/12/2006 22:51
I just re-dyed my daughter's steering wheel on her 2000 Explorer. I also touch up a seam area on on one of of my seats with the dye. There is a compnay called Leatherworld. You can order your interior color by code. I know many 2000 models had the steering wheel just turn black--this is a cheap good looking option.
David
Posted:7/13/2006 12:16
David,
Thanks for the tip. My steering wheel color has worn away considerably. I was thinking of going with the wood grain trim for the steering wheel. We'll see!
ExcursionPSD
• Milwaukee, WI, USA
• Registered on 9/16/2004
• 26 posts
Posted:7/19/2006 12:13
Here is the LeatherWorld tech web page
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, WD 65hp chip, WalkerBigTruck Muffler, RS9000, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Amsoil from MAXoil.com in diffs/trans/transfer 199k miles.
