got some ??'s towing 12,500 lb boat
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1018
4Lance
• small town, XX, USA
• Registered on 6/30/2007
• 22 posts
Posted:7/2/2007 23:16
Sorry for all the question? biggest is the coolant and towing
Just bought a 2000 limited 4x4 v-10 loaded ex with 100,000 miles on it. I have a 2004 lightning that i want to keep in the garage in the winter and be able to pull a 12,500 boat.
Just new to the ford excursion, and want to findout the things i need to know tips and tricks i guess? Thanks
What are some best bangs for your buck on performance and gas milage and towing?
k&N drop in filter? Any exhaust that doesnt sound like crap and gives some gains??
Will it be able to pull this boat alright?
What gears do i have ? plate on drivers door says nothing? axle tag says..
PM 138D
73 10 59 J14
What else should i do maintenance wise??
I have got new oil 5w30 motorcraft/filter
motorcraft plat. spark plugs it calls for
fuel filter
pcv
seafoam in tank/ and sucked threw vac. line
radiator flush
new coolant (Went to autozone to get the flush and fluid. My fluid when i bought it was orange looking. When autosone pulled up what coolant it calls for it say use DEX-Cool (Recomended) so i bought 4 gallans of it? Should i use this gm coolant?? In my factory book it say do not use ford ext. life antifreeze orange in color, and under that it say do not use Dex-Cool or any other brands that meet for spec's? What should i do?? Is the Dex cool alright ot use??
What do i need to get for the 4 wheel drive front dif and rear and how many bottles? Never had a 4x4 before so ma sound stupid??
How many qts of trany fluid for draining the pan and changing filter??
edited 7/5/2007 21:51
Posted:7/4/2007 06:02
Which engine do you have? V8 or V10?
Posted:7/4/2007 16:55
Just bought a 2000 limited 4x4 loaded ex with 100,000 miles on it. .... be able to pull a 12,500 boat. Will it be able to pull this boat alright?
No. Not safely.
PM 138D
73 10 59 J14
3.73 Open diff. That makes your tow rating 9600lbs. Hook up that trailer and you'll be over in every category. I've not got a big problem with being a few hundred pounds over but when you're a TON over then I have issues. Simply because you have to SHARE the road with others and towing that much weight with that truck ain't what I would call safe.
fuel filter
pcv
radiator flush
Brake fluid. Easy to change and [i]should[/i] be done every 2-3 years.
Don't use DEX-Cool. if the manual says not to use it . Why would you ask?? Find the coolant that meets specs and use that one.
I cannot remember the exact quantity but it is listed in your manual . Front and rear take different oil. I like Royal Purple gear lube.
How to swap fluid in your 4R100. http://www.ford-trucks.com/article/idx/9/057/article/Changing_ATF_Fluid_in_a_E4OD_and_4R100_transmission.html
