PSD fan belt replacement
Thread Statistics:     Users to Post: 6   |   Total Posts: 13   |   Total Views: 2680
ExcursionPSD
• Milwaukee, WI, USA
• Registered on 9/16/2004
• 26 posts
Posted:7/27/2006 17:26
The part numbers for the dual alternator syle upper radiator hose:
F81Z-8260-CA Ford
#22433 Gates
#88908691 AC Delco
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, WD 65hp chip, WalkerBigTruck Muffler, RS9000, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Amsoil from MAXoil.com in diffs/trans/transfer 199k miles.
Eddie Henson
• Cordova, TN, USA
• Registered on 12/8/2004
• 122 posts
Posted:7/30/2006 00:30
I'll give a thumbs up on the Evan's coolant as well. While it is a little pricey, I think it is worth it to not have to worry about checking your silicate levels. Plus with the low pressure system, the chances of blowing a radiator hose is ZERO.
Eddie Henson
Posted:8/1/2006 19:23
Evans coolant user here, too. I was never good with keeping up with the additives for the OEM coolant. Now I don't have to worry about it anymore. I keep a spare gallon in the truck with me just in case I encounter a small leak.
