HOW TO TELL IF LEAF SPRINGS ARE WORN OUT?
Thread Statistics:     Users to Post: 7   |   Total Posts: 17   |   Total Views: 11898
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:1/12/2005 20:23
Do any of you guys replace your stock endlinks on a regular basis??
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
BUSTN
• ORLANDO, FL, USA
• Registered on 2/25/2004
• 34 posts
Posted:1/12/2005 22:23
So no one has a copy or link to the tsb for the rear end?I am going to call the dealership to see if they know anything about it???
BUSTN
• ORLANDO, FL, USA
• 34 posts
Posted:1/13/2005 17:15
Ok, went to greenway ford today.they told me they could not find a tsb for the rear and I would still have to pay to fix it???Will me replacing the leafs in the back repair this problem???They are about $150 per side.I also had them cross reference the snubbers from a 00' to a 04' and they are the same part ##'s??????I am also still getting the thumping sound in the front.I tried to crank down on the swaybar endlinks and they wouldn't budge.
Would a new lift kit repair this problem also??I am trying to come up with a viable solution to this, please help!Thanks
Posted:1/13/2005 22:59
Alright, I pulled out the ol' folder of receipts for my Excursion dating back to its purchase in August of 2000. I found the service invoice that lists the fix for the rear clunking sound. This was dated 2/15/2001...nearly a 4-year old invoice. I can't believe I've owned the X this long.
Anyway, here's what it says:
C CLUNK NOISE ON DRIVERS SIDE REAR OF VEHICLE OVER BUMPS.
CAUSE: MT4730 TIME TO INSPECT SUSPENSION
TIGHTEN BOLTS IN REAR FOUND REAR SPRING
JOUNCE BUMPERS HITTING SPRING INSTALLED
UPDATED BUMPERS
MT MT4730 TIME TO INSPECT AND TIGHTEN
BOLTS IN REAR AND INSTALL NEW UPDATED BUMPERS
6031 WF94 (N/C)
2 YC3Z*4730*AA BMPR
ASY-RR AX (N/C)
FC: N51 42
PART#: YC3Z*4730*AA
Here's the part number information from http://www.fordpartsonline.com
Item: YC3Z4730AA
List: $15.43
Core Price: $0.00
Price: $11.57
Rear suspension - Suspension components - Bumper
Bumper Back 2000 - 2004
I don't see any TSB information listed here, I just remember the service manager telling me that this repair was covered by a TSB. The dealership will be able to tell if the above part number replaced another part number. It seems that it would be a replacement part because of how it was listed: "install new updated bumpers." I never had the rear clunking problem after they performed this fix.
Just because the part number is the same for 00-04, doesn't mean that your '00 X has the same part number. It could have an older version of these...it seems like mine did judging by the service invoice.
New factory leaf springs seem overkill for the fixing of a $11.57 part. A suspension lift would only help if you replace the rear springs. Many kits come with rear lift blocks and use the factory leaf springs...so you'd be back at square one.
Hope this helps.
BUSTN
• ORLANDO, FL, USA
• 34 posts
Posted:1/13/2005 23:29
Thanks,I really appreciate it!!!This helps me out alot.I'll go pick them up tomm.I have one more question.This may sound stupid, but the ex 4x4 does not run springs like a car,right?Whaen the term spring is used it is for leaf springs,right?Thanks again!!!!!!!!!!!
Posted:1/14/2005 07:39
There are leaf springs and then there are coil springs. The 4x4 Excursion has leaf springs on the front and rear.
Leaf springs look like this:
Coil springs look like this:
(Note that neither of these above pics are from an Excursion)
And then, here's what the snubber looked like on my Excursion. Perhaps yours is an earlier part and looks a little different?
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:9/7/2011 23:15
Hello, I am getting a real bad thumping noise coming from the rear leaf springs.I got under and looked and could tell it was the rubber snubber hitting the front of the leaf springs when stopping.As soon as I let off of the brake the truck will settle back down and make the noise.Any ideas???I am also getting a clanking in the front when turning??Please help it\\'s driving me crazy!!!!!!!!!!!!!!
having the same trouble on my leaf spring. i cant help it! i dont know what to do. my mechanic told me to change my leaf spring. but i dont know how to change it. please help me on this too. thanks a lot!
