Liftgate height
Thread Statistics:     Users to Post: 7   |   Total Posts: 17   |   Total Views: 1643
John Crisford
• Dallas, TX, USA
• Registered on 2/19/2005
• 23 posts
Posted:3/16/2005 21:44
At 6'5", I find the spaciousness of this beast refreshing.
However, I have found one part on this thing that crunches me: the liftgate, when opened, hits me (or should I say that I hit it?) right in the forehead. I have to duck under it to reach inside to load or unload.
Does anyone have any experience with this liftgate being opened a couple of inches higher? I guess the more specific questions are 1) do the hinges open up a little more? and 2) if slightly longer gas lifts are fitted, allowing the gate to go higher, will those cylinders be short enough to fit in their space once the gate is shut?
Thanks much!
Posted:3/16/2005 22:32
Hi John,from the photo of Blue I honestly can't tell if you have a 4x4 but if you do go purchase a set of struts for a 4x2 Excursion as they'll be a couple inches longer to clear the scalp and the liftgate will close as normal
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:3/17/2005 16:11
As Bill said the the 2 wheel drive X has longer release shocks since the truck sits lower and will not be hitting the rafters of the garage roof I installed them for the same reason. A note of caution though....The rear lift gate is HEAVY...get help holding the lift gate as you remove and replace the oe ones.
Mine was on back order as it became common knowledge and everyone wanted them at the same time. Should cost around 20-25 a pc.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
John Crisford
• Dallas, TX, USA
• 23 posts
Posted:3/17/2005 22:03
Well, I appreciate the suggestion. However, I have a 4x2, so I guess i've got the longer ones already... but I need more height! Suggestions?
Thanks!
John
Posted:3/17/2005 22:15
Stock 4x4 rear blocks are like 2 1/8""- 2 3/8" tall which might help since you're in a 4x2
edited 3/17/2005 23:25
Posted:3/17/2005 22:25
Take off your shoes before opening the rear lift gate!
Sorry, had to be the smartass!
John Crisford
• Dallas, TX, USA
• 23 posts
Posted:3/18/2005 00:10
Seems like a crazy reason, but I guess I could always install a suspension lift kit to raise the liftgate height! yuk yuk...
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:3/18/2005 05:40
Anyone have the part #'s for the arms?? My wife wants it higher also!!
And since were on the subject of rear doors, can you make the barn doors open wider? I saw on a site that it was open all most all the way!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
DoubleX
• Colmar, PA, USA
• Registered on 3/3/2005
• 24 posts
Posted:3/18/2005 05:49
There's a little spring retaining clip setup that limits how far the barn doors will open. Press it in and it'll come off its pin. The barn doors will swing open till they're perpendicular with the body. To close just reattach the clip, it's really simple.
Scott Stover
• 354 posts
Posted:3/18/2005 06:52
Sweet, Thank you for the help!!
K&N
Gibson Catback
"Custom" Kickplates
Liftgate height
