rear differential question
Thread Statistics:     Users to Post: 5   |   Total Posts: 8   |   Total Views: 1076
clarence bjarnason
• brandon, XX, Canada
• Registered on 3/13/2005
• 37 posts
Posted:4/6/2005 09:38
hello everyone. i was wondering if my 2000 excursion 4x4 has a 10.25 rear end? is that the dana or.... i thought i remember someone saying its not really a dana but something else.
and also does anyone make a rebuild kit for this rear or do i have to go to the dealer for the individual parts?
thanks
clarence
Posted:4/6/2005 10:51
To my knowledge Clarence the rear axles on the X's are Sterling 10.50 ring geared units.
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:4/7/2005 14:29
Yepper, 10.25 Sterlings....
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Posted:4/7/2005 15:15
I thought it was 10.5 well thats what we had in our '99
edited 4/9/2005 10:13
clarence bjarnason
• 37 posts
Posted:4/8/2005 12:51
so then does anyone have a list of the service parts i need if i wanted to rebuild the rear end??? like the bearings i need or the seals. how about a crush sleeve?? is there one? i talked to the ford dealer and all they said was' tell us what you need and we can get it'. well, i dont know what i need but im sure a rebuild kit or service kit would get'er done no? then if i find out i need gears thats a whole nother ball park. right? or..........
clarence
Posted:4/8/2005 13:14
clarence
Excursions have a 10.5" Sterling rearend.
You can buy a "rebuilt kit" for your rearend that will include all necessary parts, etc. Gears and traction differentials (limited slip or locker) are additional. Typically, if you're installing new gears, you'll also get the rebuild kit as well.
This is just strictly referring to the rearend. It doesn't include axles, axle seals or anything else. What are looking to do?
J-Douglas
• San Antonio, TX, USA
• Registered on 3/18/2004
• 90 posts
Posted:4/9/2005 00:01
Both my Excursions have a Sterling 10.5" rear end. Solid as a rock!
clarence bjarnason
• 37 posts
Posted:4/9/2005 20:10
i have a growling noise coming from the rear end. i lifted the rear up and crawled underneath, then started the truck and put it in drive. the growling is coming from the pinion area. i guess it could travel throughout the whole rearend but i think that is where it is coming from. regardless, its a rearend issue. so anyway, i wanted to replace all bearings and seals and thats it. unless of course i have pinion and ring gear problems that arose from bad bearings.
that is the kind of rebuild kit i am looking for.
hey, here is another one. i just got my f350 springs in today and lift blocks for the back. the lift blocks are straight and not tapered. im not sure what the stock ones are but someone before had said that they have to be tapered. is this true? if so then how come the f350 doesn't have to be?
anyway thanks for all the replies so far
clarence
