2000 Excursion 7.3 OIl Leak
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 2425
speckfisher
• Missouri City, TX, USA
• Registered on 2/2/2007
• 15 posts
Posted:2/3/2007 14:24
I seem to have an engine oil leak from the front of the engine . It looks like its coming from a hose. I know it has a trans. cooler and it has hoses going to the rad. My question is does it also have an oil cooler that has hoses running to front of engine.
Posted:2/5/2007 06:56
It could be a leaking intercooler hose...specifically the CAC hose. A couple years back I had a problem with an oil leak at the front of the vehicle and I pinpointed it to the CAC hose.
I did an install article on how to replace it:
http://www.supermotors.net/clubs/fordexcursions/installs/install_5/index.php
Full pictures can be found at:
http://www.supermotors.net/clubs/fordexcursions/vehicles/registry/9/24716-2
speckfisher
• 15 posts
Posted:2/6/2007 05:12
Thanks I will ck that out
Soaggydogg
• Little Rock, AR, USA
• Registered on 3/5/2007
Posted:3/5/2007 11:13
Don't forget to check the steering cooler too.
pilot76180
• Ft. Worth, TX, USA
• Registered on 10/31/2009
Posted:10/31/2009 12:39
Just found this place. I saw your post on the cac hose replacement. I need to start using your Ford dealer. Mine wanted $800 to replace the 4 cac hoses!! I'm going to do it myself, and learn how to work on my Excursion.. I'm not a mechanic, I'm a lover, but I'm tired of them ripping me off! $400 labor to replace the alternator! Screw them.
