aluminum transmission cooling pans
Thread Statistics:     Users to Post: 6   |   Total Posts: 17   |   Total Views: 1570
Posted:5/1/2003 21:43
pictures will be coming(i hope,need help)when i am done with the pictures,the trans comes back out for inspection and more tech.my X is a test mule that i fell in love with.my wife and i went and looked at the Burbs a few weeks ago;she says it dont compare,i says you are right,honey
Mike, she sounds like a keeper!!!
Looking forward to your call...
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:5/2/2003 13:48
Eric
please email your phone # to me,i cant find it(duh)[email protected]
mike
Posted:5/2/2003 20:27
Eric
mike
Done!
gearman
• 336 posts
Posted:5/3/2003 21:06
ok
i dont know if posting prices is ok here(Eric might kick my behind)pans will fo for 265.00 including filter and gasket.painted pans will be 35.00 more(not worth it) polished will be 100.00 more(for what,bragging rights?)pan holds 3to 4 more qts,has magnetic drain plug.has boss for temp sensor.working on pictures,these are the best pans i have seen.
Dan Nguyen
• Yuba City, CA, USA
• Registered on 11/13/2001
• 22 posts
Posted:5/4/2003 09:06
Gearman;
I too am interested in the pan, when you get the prices, let me know. I have researched the PML pans in the past and have wavered between the PML and the Mag Hytec pans. I do know that mag-hytec pans require the cross member be moved otherwise it is too deep to fit.
On another note, there was a discussion between pans and tranny cooler. The arguments are;
1. Pans add fluid but the worse condition which the fluids get hot, ie. driving without adequate air flow @ 30-40mph with out TC lock up; the finned pans don't cool any extra.
2. The filter statement you made regarding pickup does negate the advantage of the pan.
3. An additional tranny cooler will cool some if there is still air flow through the point the cooler is installed vs. pan (I think)
4. Price $400.00 for pan (new fluids included) vs. about $100.00 for cooler.
So what is being said is that IMHO a pan although does add more fluids and a very small amount of cooling, is only effective if you are moving at cruising speeds, however in conditions which these 4R100 gets hot (slow moving conditions) the pans would at best keep your fluids from french frying your tranny a little further than normal ?
But all said and confused, I am opting for pan and tranny cooler on both my rigs to get the added safety.
gearman
• 336 posts
Posted:5/4/2003 14:31
coolers are not that effective below 35 mph(they need airflow)the best setup for coolers(i posted in another thread)is to run 2 coolers in parallel after the radiator.diesels will benefit from a deeper pan because they can heat the fluid much easier than a gas motor.it also helps tremendously having an aftermarket torque converter,TransGo shift kit,and synthetic fluid.
mike
gearman
• 336 posts
Posted:5/4/2003 20:25
am sending a PML pan to Eric Long for evaluation.he will have it in a week.
