Steering Stabalizer
Thread Statistics:     Users to Post: 12   |   Total Posts: 17   |   Total Views: 3146
RickyG
• Lubbock, TX, USA
• Registered on 5/10/2003
• 24 posts
Posted:7/3/2003 13:29
I know I have read this somewhere. Did someone replace there stock steering stabalizer with a new one, Ranco maybe. Since the search doesn't work I have gotten tired of looking through posts. I know you can buy the single or dual add-on but I would like to stay stock. None of the parts houses seem to have a number on file. Thanks in advance. Ricky
ehumaui
• Santa Clara, CA, USA
• Registered on 1/26/2003
• 36 posts
Posted:7/3/2003 16:35
I had an extra rancho 5000 front shock and removed the stock stabalizer and it fit right in. The only modification I had to do was move the Ubolt clip over for the extra length. (Note: I had to notch the steeering bar to fit the up bolt clip around.)It works great.
Russell
2000XLT V10 BBk throttle body, throttle body spacer, KN flpk, Skyjacker 6" lift, Eagle alloy 589, 35" Xterrains, Rancho 9000, Firestone air springs rear, Hellwig rear sway bar, Warn Rio Grande push bar, Custom rear tire subwoofer, custom Zoo dad mod, Too may tire changes since I lifted it!
• 0 posts
Posted:7/3/2003 16:54
I got a FOX stabilizer, works great. BTW, shocks are completley different than a stabalizer, you need a 50-50 valve, which shocks dont have. $147 is what i paid for it, its better than a pro-crap beater for 50 bucks but not the best out there. If you just want a factory replacement go with a rancho or whatever, they are all about the same. Unless you wanna sport for a Bilstein and rig up some brackets.
Posted:7/5/2003 08:09
Summit Racing carries steering stabilizer shocks. I have a Pro Comp stabilizer shock.
MrRottnDog
• New Lenox, IL, USA
• Registered on 2/19/2002
• 103 posts
Posted:7/6/2003 22:10
Donahoe racing now sells a very slick dual steering stabilizer using Bilstein Nickle Plated 5100's.
Very eXpensive though!
MrRottnDog
edited 7/6/2003 22:11
CoolStrategist
• Registered on 1/11/2005
• 79 posts
Posted:4/9/2005 22:55
rottndog,
Where can I order just the Donahoe dual steering stabilizer. I did a search and cannot find the stabilizer separate from a lift kit. Is this still one of the best out there? I need to order one this week to have it put on the same time I have the Rancho RS9000x shocks put on.
Thanks.
Black 2003 4x4 Limited V10; 285/75 BFG Dueler Revos; Viper 791xv Remote Start and Alarm with voice module; Hellwig Rear Sway Bar; Go Industries Rancher Grill Guard; Limo Tint; Rancho RS9000X Shocks; Line Of Fire LED Lights; WeatherTech Dark Window Deflectors; 2005 Heated, Signal, Running light TTT mirrors; PIAA 550 Driving/Fog Lights; PIAA 9007 Headlights w/upgraded wiring harness (bright!); PIAA 9005 fogs; Optima Yellow Top battery
CoolStrategist
• 79 posts
Posted:4/11/2005 19:30
If I go with the Rancho RS5410 steering stabilizer that some recommended do I also need to order the bracket kit for my aftermarket guy to install the stabilizer?
And if I stay on the road is there any benefit to installing the dual version?
85MH325
• Eastern, IA, USA
• Registered on 3/20/2004
• 54 posts
Posted:4/11/2005 20:55
I just bought a Summit Racing house brand steering stabilizer that fits the stock brackets. It was a whopping $33. My former off-road life taught me that a single stabilizer is more than sufficient for on-road use. The Summit Racing stabiizer is a little beefier than the stock Ford unit, and actually does a very nice job.
Unfortunately I don't have info on the Rancho stabilizer. I didn't want to mess with brackets on mine.
Good luck! Roger
CoolStrategist
• 79 posts
Posted:4/11/2005 21:40
So what do you guys think of this Fabtech dual parallel mount? Would this work well (significantly better handling/control) on my 2003 X?
http://www.rockymountainsusp.com/W_stbzr_Fabtech.htm
It appears that this fits right on the existing OEM mounts.
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:4/12/2005 20:34
www.4wheelonline.com
I got the Pro Comp ES 2000 and love it, took me about 10 min to change, and love it!! I think it was around 38$ or so....
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Steering Stabalizer
